will a y7 work?
Old 08-18-2004, 07:25 AM
jman30513's Avatar
Default will a y7 work?
i have a 98 ex y8 with a spun bearing and have found a y7 bottom end
will it bolt right up to my head?
im hearing that i might have to do something with the knock sensor
and links would be nice
and advice
the guy is waiting on me to tell him if i want the motor
thanks all
jman
jman30513 is offline
Old 08-18-2004, 07:32 AM
Spade's Avatar
Default Re: will a y7 work? (jman30513)
yup, it'll work fine since the Y7s have a knock sensor too.
Spade is offline
Old 08-18-2004, 07:33 AM
jman30513's Avatar
Default Re: will a y7 work? (Spade)
so is it just a direct swap or do i have to do more?
sensors and all?
please help
jman
Old 08-18-2004, 07:58 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">yup, it'll work fine since the Y7s have a knock sensor too.</TD></TR></TABLE>
Mine doesn't have it....
Do you mean they have a threaded boss to screw one in?
EE_Chris is offline
Old 08-18-2004, 08:01 AM
jman30513's Avatar
Default Re: will a y7 work? (EE_Chris)
so does a y7 have knock sensor or not?
hmmmm
Old 08-18-2004, 08:11 AM
99hatch's Avatar
y7 doesnt have a knock sensor only y8 does
99hatch is offline
Old 08-18-2004, 08:24 AM
jman30513's Avatar
Default Re: will a y7 work? (99hatch)
do i have to run the knock sensor?
im being told that it isnt necassary
true?
will i get codes?
jman
Old 08-18-2004, 08:31 AM
civic-4-ges's Avatar
You will get codes, but you already have one on your y8 block, so just unscrew it and screw it into your y7 block
civic-4-ges is offline
Old 08-18-2004, 08:39 AM
jman30513's Avatar
Default Re: will a y7 work? (civic-4-ges)
i believe the y7 doesnt have a knock sensor hole?
right or wrong?
thanks
jman
Old 08-18-2004, 08:41 AM
a d is a d no matter how you look at it and you do not need a knock sensor for v-tec.
scratchy is offline
Old 08-18-2004, 08:44 AM
EE_Chris's Avatar
Default Re: will a y7 work? (scratchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchy &raquo;</TD></TR><TR><TD CLASS="quote">a d is a d no matter how you look at it and you do not need a knock sensor for v-tec.</TD></TR></TABLE>
Tell that to the Y8 ECU....
EE_Chris is offline
Old 08-18-2004, 08:47 AM
jman30513's Avatar
just comfirmed that i will throw a code but no performance probs
if this wasnt right, how do ls/vtec owners get by with not having a knock sensor?
jman
Old 08-18-2004, 08:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jman30513 &raquo;</TD></TR><TR><TD CLASS="quote">i believe the y7 doesnt have a knock sensor hole?</TD></TR></TABLE>
It has a threaded hole for one, Y7/Y8 blocks are exactly the saem, except for the sleeves
spade... y7's have knock sensors?... last couple y7's i've worked on that was a negative bro
menkio is offline
Old 08-18-2004, 08:51 AM
pane93civhb's Avatar
isnt the knock sensor on the head and i think the knock is only neccesary for dual cam. motors.. a single will run vtec fine with the vtec wire and oil pressure or whatever that 2nd wire is. im pretty sure not the expert though. just but a d16z6 bottom end or zc vtec y test it doing a mini me. may create more power then the stock y8 does though.
pane93civhb is offline
Old 08-18-2004, 08:52 AM
Default Re: will a y7 work? (DewMota)
If you see any obd2 y7's with knock sensors (don't know about obd2b), then the ecu is not looking for it, or even ocnnnected to it.
Old 08-18-2004, 09:44 AM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota &raquo;</TD></TR><TR><TD CLASS="quote">spade... y7's have knock sensors?... last couple y7's i've worked on that was a negative bro</TD></TR></TABLE>
I meant that the Y7 has a boss for the knock.......not drinking coffee in the morning ownz me.
Spade is offline
Old 08-18-2004, 10:04 AM
Ricey McRicerton's Avatar
I meant that the Y7 has a boss for the knock.......not drinking coffee in the morning ownz me.</TD></TR></TABLE>
Ya right you colorbind bastage.
Ricey McRicerton is offline
Old 08-18-2004, 10:07 AM
Spade's Avatar
Default Re: will a y7 work? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
Ya right you colorbind bastage. </TD></TR></TABLE>
Okay you got me.......I'm stupid and I don't know anything, never listen to what I say cause I don't know ****
EDIT: GDamn noobie mods
Spade is offline
gogolf0401
09-28-2012 08:43 AM
98greensi
08-11-2010 10:00 AM
tobe1424
02-26-2006 09:41 AM
theeogflip
37
06-21-2005 05:04 AM
EK_vzla
02-03-2004 06:32 AM
Quick Reply: will a y7 work?
  • Ask a Question
Question Title:
Description:
