Need help with the new swap-- inside!!
Ok, kind of a long story, but I'll try to make it short as possible:
1998 Civic EX, recently had a obd-1 ls motor installed in it by a shop in town.
Recently purchased a new 1996 GSR motor, obd-2. I guess the problems are, we assumed we needed to put a OBD-1 vtec dizzy in, to mate up to the obd-1 wiring that was done in order to make the obd-1 wiring work. Also, we changed the injectors from the old LS motor into the GSR so they also mate with the obd-1 wiring. Now, is there anything else that needs to be changed on the obd-2 GSR motor to fit into the obd-1 changes that was made to the car?? please help!!
The car hasn't started, it just turns over, so I'm thinking its a timing issue.
Re: Need help with the new swap-- inside!! (integranator)
Thats weird i'm having the same problem with my swap i did with my crx so when u find out the problem please let know too.
Modified by nelsonb16 at 3:56 PM 1/23/2008
Re: (Datphan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Datphan »</TD></TR><TR><TD CLASS="quote">when you swap out the dizzy, and re-pin it etc.. did you set the engine to tdc on #1 cylinder and reset the rotor in the dizzy to #1 also?</TD></TR></TABLE>
Do we need to re-pin the dizzy if we are running a obd-1 dizzy?
hate!
10
04-30-2010 09:02 AM
so simple
03-03-2007 08:12 PM
