any real problems running obd1 motor on obd2?
Old 04-28-2010, 04:09 PM
hate!'s Avatar
Default any real problems running obd1 motor on obd2?
I have a 99 ex, and im wanting to swap in a obd1 LS longblock. i know idealy i should run a obd1 p75 with a jumper, but i have a obd2 p75 laying around, so if i just jump it from obd2b-obd2a i will have that covered. but my question is, will this have any real negative affect on the motor? i know i will have a cel for a missing sensor or 2, but thats not really a big deal concerning a CEL. but will that affect the motor? thanks.
Old 04-28-2010, 05:04 PM
Blahblah718293's Avatar
Default Re: any real problems running obd1 motor on obd2?
the only thing i think it may effect is the dizzy, idk about the obd1/2 connectors.
its also illegal to swap in a motor thats older than the car so if your from cali they may give you ****.
Old 04-28-2010, 06:37 PM
b20hatchek's Avatar
i think you can run a ob2 dizzy from a ls on your obd1 ls, enjoy
Old 04-28-2010, 08:20 PM
D16SiHatch's Avatar
you can ^, obd1 and obd1 dizzys are the same internally, it's just the connectors that are different.
the obd2 ecu will look for a crankshaft fluctuation sensor, and your car will not run without it. luckily there is an easy way to bypass it
http://ff-squad.com/wp/?p=309
and yes you will throw a code for a missing secondary o2 sensor.
Old 04-28-2010, 10:54 PM
b20hatchek's Avatar
thats what i thought
Old 04-28-2010, 11:27 PM
Technical Hero
HondaPartsHero's Avatar
he should already have a secondary O2 being its a 99 EX so it shouldn't throw a code for that. You'll need to use your EX injectors for plug and play. Also you'll need to swap alternator plugs. Also if I'm not mistaken you'll need to rewire your intake air temperature sensor for the OBD1 style plug due to yours being in the intake arm and the B18's is in the intake manifold, that or place your IAT in whatever intake arm you use. Just repin your distributor to run the OBD1 from the LS.
Old 04-29-2010, 12:55 AM
b20hatchek's Avatar
whats up with all the wire junkies here on h-t, no you dont swap alternater plugs you just swap the alternater, and i thought the tps sensor plug was the same on obd1 and obd2
Old 04-29-2010, 01:05 AM
Technical Hero
not everyone has an OBD2 alternator laying around as a spare, but as an alternative to swapping the plugs you can go this route
vs
http://ff-squad.com/wp/?p=425
Old 04-29-2010, 02:54 AM
b20hatchek's Avatar
who says he doesnt but atleast your nice enough to show another route
Old 04-29-2010, 07:37 PM
hate!'s Avatar
opted not to get the motor, found out it was actually obd0, i would rather just order a b20 and be headache free. still good information i have always wondered about. thanks for all the help guys
Old 04-30-2010, 09:02 AM
b20hatchek's Avatar
your gonna love that b20, all the low end torque, im enjoying my 2nd b20 and love it
posho
10-30-2009 09:42 AM
integranator
01-23-2008 10:03 AM
knightnam
07-30-2005 03:07 PM
1hotvtec
10-12-2003 07:29 PM
1man
07-21-2003 11:45 AM
Quick Reply: any real problems running obd1 motor on obd2?
