NEED HELP WITH CLIMATE CONTROL
need help with climate on a 94 ej1
need help with my climate control on a 94 ej1 so the climate control dont light up and i wanna take it out so i could check the bulbs. can anyone tell me how to take it out or can someone guide me through on how to take it out thanks
Modified by I LUV MY EJ1 at 8:06 PM 10/21/2008
-remove the lower console (4 phillips screws)
-remove cd player
-remove the easily accessible phillips from the CC (it's towards the back of the CC)
-remove the 5 smaller phillips screws that are towards the face of the CC (i used and L shaped phillips)
-use a pliers to remove the heater fan switch and wiggle it out
-remove the heater cable with a pliers and then unscrew the lever stopper with your hand
-remove the green connector (this is tricky to get to, but i was able to get it nicely with a little knife)
-you should be able to slide the CC out of the dash now
-there's one little phillips screw that connects a black piece of metal to the CC, remove that
-then there are like 5 tabs that you need to undo to remove the face of the CC
-if all was done correctly you should be staring at your 2 #74 bulbs!
Modified by NBPej1 at 12:51 PM 10/22/2008
-remove cd player
Homotor
07-26-2009 08:47 PM
ner0x
06-23-2005 07:17 PM
Tomek
10-05-2002 05:46 AM
