Piston Rings
Old Oct 9, 2002 | 09:23 AM
Islander's Avatar
New User
Default Piston Rings
I think one of my oil rings are bad because I burn a hell of amount of oil. Yesterday I drove from Fortlauderdale To Miami and when I got to Miami, my oil level on my dip stick was on the low level mark. My Engine was build by JG a few years ago, with Arias Pistons and Saenze rods(ductile sleeves). My question is what's the best BRAND/TYPE of piston rings I should use on the rebuild.
Old Oct 9, 2002 | 11:38 AM
brian b's Avatar
New User
Default Re: Piston Rings (Islander)
total seal gapless..
Old Oct 9, 2002 | 05:45 PM
speedworks's Avatar
Default Re: Piston Rings (brian b)
put total seal gapless and you will use about 50 quarts of oil between ft. laurderdale
and miami. total seal rings are total ****. i suggest you call arias and get you a set of rings. just ask around this board and youll see i am right
Old Oct 9, 2002 | 05:47 PM
PrecisionH23a's Avatar
Default Re: Piston Rings (speedworks)
yep he is right, total seal is total ***. if the arias deal doesnt work out id run hastings piston rings, you cant go wrong with them.
Old Oct 9, 2002 | 05:48 PM
ekb18c's Avatar
Just call up Arias and get some rings from them.
Old Oct 9, 2002 | 06:39 PM
Islander's Avatar
New User
Default Re: Piston Rings (GudeH23a)
Where can I get hastings rings from? How much are they?
Old Oct 10, 2002 | 04:48 PM
speedworks's Avatar
call arias direct, they were about 104 with overnight shipping. super nice people
Old Oct 10, 2002 | 08:31 PM
roydogg's Avatar
I'm kinda having the same problem and gonna turbo in the near future. Since I'm gonna change the rings shouldn't I do the pistons too or am I ok with just the rings.I have a 94 LS with 116xxx, can it handle boosting 7-9 psi daily? I've done the valve seals and it stopped it from burning like crazy but still is.
[Modified by roydogg, 5:31 AM 10/11/2002]
Old Oct 11, 2002 | 02:45 AM
speedworks's Avatar
Default Re: Piston Rings (roydogg)
it would be a wise decision
MoreBoost!
Jan 31, 2008 10:26 AM
all-mtr-teg
12
Jul 28, 2007 08:48 AM
riceball777
Jan 17, 2004 09:41 PM
Aeka GSR
Sep 28, 2003 11:15 AM
non-VTEC
Oct 26, 2002 08:15 AM
