MY CEL is gone??
Old 05-08-2007, 09:03 PM
ph0shizzle's Avatar
Default MY CEL is gone??
alright well usually when i turn on my car i put it in the ignition on position till i see my CEL go off then i crank on my car to turn it on. but recently when my car is in the on position there is no CEL. recently my friend was driving my car and downshifted to 2nd and my car was jerking a lot as soon he downshifted it. im guessing that has to do with this problem? but what is wrong or is this normal? btw, its a 97 civic hatchback with a obd1 jdm d15b. ive had CELs though but it never really affected my driving much.
Old 05-08-2007, 10:09 PM
ph0shizzle's Avatar
Default Re: MY CEL is gone?? (ph0shizzle)
some1?
Old 05-08-2007, 10:23 PM
S2k Hybrid's Avatar
If you're using a jumper harness, take a close look at the pins. Maybe something a wire poped out
Old 05-09-2007, 04:39 AM
EE_Chris's Avatar
If the CEL doesn't come on for 2 secs while the fuel pump primes and then turns off when the fuel pump stops, then something is wrong...it's not normal.
A18 (on an OBD2a Civic) is what controls the CEL. Ground it manually to see if it turns on the light. The other side of the bulb is fed battery voltage with the key 'on' or 'run'.
Old 05-09-2007, 05:30 AM
ph0shizzle's Avatar
Default Re: MY CEL is gone?? (EE_Chris)
do you think its because a wire popped out? or what?
Old 05-09-2007, 05:57 AM
EE_Chris's Avatar
I think if you troubleshoot it, you'll have your answer.
slowesteg
10-13-2011 02:54 AM
bowdown201
04-29-2009 07:21 AM
CivicSwapper
11-07-2006 06:15 PM
O16581724 5 2 5
11-16-2005 04:26 PM
Soled Out
01-23-2003 06:59 PM
Quick Reply: MY CEL is gone??
