B throttle body on a d ?
Old Feb 24, 2007 | 09:38 AM
RACEPAK's Avatar
Default B throttle body on a d ?
hello everyone.
i got a spare b serise 62mm tb without a tps. i was bored today so i checked if it fits the d manifold in my car, and it did.
do you think its worth the $ to get a new\used tps or maby to use the one from the older one and rock the b tb? for maby a few horses?
btw, the engine is a turbo'd D14! not a D16!
thanks...
Old Feb 24, 2007 | 01:48 PM
RACEPAK's Avatar
Default Re: B throttle body on a d ? (RACEPAK)
ok so i decided im gonna do it.
on the right:my current tb is a obd2 the one that comes with the 3 wire iacv on it.
the on the TB iacv port is plugged with a plate, because i have a z6 manifold with a obd1 iacv now. (i did a obd1 swap)
left:the b16 TB that i want to use is a obd1 with a fitv on it.
will it be ok if ill make a blocking plate for it? cause i dont have a fitv on my car now...
Old Feb 24, 2007 | 01:49 PM
DaveF's Avatar
yes, i block off the fitv all the time, those things are a honda headache. most idle problems are caused by it...
block it off
seanbev24
May 18, 2009 02:03 PM
seldon
Oct 18, 2008 09:42 PM
boomersz
Apr 15, 2007 09:42 PM
boomersz
Apr 15, 2007 12:36 AM
precisionelite
Apr 23, 2006 04:59 AM
