Need help with problem, I have videos to help
Old Oct 11, 2004 | 06:16 PM
bambbrose's Avatar
Default Need help with problem, I have videos to help
I've had this problem all weekend and have been trying to figure it out. I apologize for the length but I need your help badly to figure this out
I have a 1996 dx coupe, d16y7. I put a d16y8 intake manifold on it a couple months ago, everything worked great.
This weekend I tried converting to obd1 so I can use uberdata.
I replaced the ecu with a P06, and used a JKobdconversion obd2a-obd1 harness.
I also replaced my Y7 throttle body with a Z6 throttle body, and put a Z6 2 wire IACV to work with the obd1 ecu.
I wired it up according to katmans articles on ff-squad.
Now for the problem. First, I have no CEL. It just plain idles weird. It's not like the vaccum leak idle (up and down), it's a stuttering, sounds almost like I have an agressive cam in or something. It idles around 700-800 when warm, but occasionally drops down to 550 or so (this is when the stuttering happens worst), and then brings itself back up to 800, and then repeats this process.
Now for the weird things, My IACV hum's loud as hell. Refer to videos to see what I mean. Now it hum's a little bit all the time, but it's really loud when it does the idle drop down to 550. Also, I'm just about to turbo my car, so I have a narrowband A/F gauge installed. I noticed that at idle, my gauge doesn't bounce like it used to instead it stays lean, at part throttle it bounces from lean to rich, and at WOT, it reads lean all the way. It never did this before swapping the ecu's
When I unplug the IACV while running, the engine doesn't seem to change much besides the humming going away, but when I plug it back in the humming sound is extremely loud, and the idle will jump to 1500 for 20 seconds or so and then die back down to 800.
Also when I start the car, with the engine warm, it used to jump to 1500 and then quickly settle at 700, now with the new ecu, it'll stay at 1800 or so until I tap the throttle, and then drop down to 800 and start the process stated above.
Things that I have checked:
-I tried using a different obd1 IACV, no luck, and still the same humming sound
-made sure air was bled out of coolant
-Checked the fast idle valve, and made sure the white screw was screwed in all the way
-Tried switching the 2 wires on my IACV plug, made things worse but still no CEL
Things that I can think of that I still need to check:
-try swapping out a different p06 ecu
I've almost come to the conclusion that maybe the D16y7 engine can't be run correctly on a p06 ecu. Has anybody done this sucessfully? My ecu currently isn't chipped.
I really need your help guys, I need to get my car running right so that I can install my turbo. Here are the vids:
http://parkinginlots.com/images/iacv1.AVI humming sound
http://parkinginlots.com/images/iacv2.AVI unplugging iacv
http://parkinginlots.com/images/iacv3.AVI exhaust sound
http://parkinginlots.com/images/iacv4.AVI more humming
thanks guys I appreciate any help. I need to get my car running right so I can bewst eet
Old Oct 12, 2004 | 06:20 AM
bambbrose's Avatar
bump
Type R Marcin
12
Nov 9, 2014 10:11 AM
sojo03
Aug 13, 2012 10:02 AM
Unmexicano
10
Mar 21, 2011 08:19 PM
Bakersfieldgsr
Nov 11, 2007 05:57 PM
bambbrose
Oct 10, 2004 08:13 AM
