map sensor
map sensor
i have had some probs with my car recently.. motor kept throwin a code so i had it checked and said fuel mixture, couldn't figure it out and took it to honda.now another one came up saying map sensor. they tell me its bad and i replace it..it doesnt fix the prob and they also believe the 02 sensor is bad so i replaced that.. but still no change! the car has a very rough idol..u can smell the gas and at times when the check light comes on i can't go past 3500 rpms.. now i kno that is because its trying to protect the motor. it will idol between 200 and 600 rpms.. after letting off the gas it will drop to 0 rpm's and almost stall out then brings it back up to 200 rpm's..i am lost and im goin to check the plugs tom but unsure..almost seems like a misfire is happening while it runs. honda has had my car several times and apparently doesn't kno the cause of the problem. i did have a vafc in my car but later took it out. u think the wiring might of cause this? im lost and don't kno what to do thanks
