magical coolant
Re: magical coolant (SiTEC)
sometimes there s just a very small leak..my son s accord kept loosing coolant and even the honda dealer couldnt find it..finally a rad. shop found it by preasure testing to hell..it was a pin size hole in the hose
HT White Ops
Guaranteed cure !!!
93 EG coolant keeps disappearing... any advice???
Bar's Leaks Cooling System Sealer permanently seals leaks in plastic, aluminum, and metal radiators, heater cores, blocks, heads, gaskets, and freeze plugs. Prevents rust, cuts electrolysis, and lubes water pump. Compatible with all brands of antifreeze including extended life. Use one bottle for 4 cylinder engines and two bottles for 6 and 8 cylinder engines.
Bar's Leaks Cooling System Sealer (5.5 oz.) $2.99
Re: Guaranteed cure !!! (BlackDeuceCoupe)
my 94 civic is doing the SAME DAMN THING
its leaking a full tank a collant a week yet there is no smoke no leak.
i just keep telling myself ill fix it after the swap.
HT White Ops
Re: Guaranteed cure !!! (SiTEC)
i can get that at pepboys ?
New User
Re: Guaranteed cure !!! (KAMiN)
have the same problem in my 94 ex. I had a post about 1 month ago concerning it. never did figure it out, it stops sometimes but then other times I go through a reservoir of coolant every 3 days
Re: Guaranteed cure !!! (94civicx)
damn i hate that. ill get some this week pre-swap.
i went out to get bar's leaks and they were out of stock of that exact bottle you had posted. instead they had bar's leaks in a clear bottle in powder form, is this ok?
[Modified by SiTEC, 10:08 PM 12/30/2001]
HT White Ops
SeanK325
06-22-2010 02:52 PM
vtecdc2
11-04-2003 06:44 PM
