Ls swap question about one of the mounts
I understand about ALL of the mounts, except the one in RED. How do I get this (b18b motor) to fit into my EK? What parts from what car? Thanks.
[Modified by civcexcoupeblack, 6:03 PM 3/20/2003]
Re: Ls swap question about one of the mounts (civcexcoupeblack)
Ok the red mount u can use is the rubber mount attached to the A/C mount. You can use ur stock one or that one. But you have to remove the A/C compressor I believe cause it wont have enough clearance. Could be wrong though u might be able to use ur that A/C compressor.
The mount on the Top is the WRONG one thats for 94+ Tegs, you can only use that if u are swappin it into an EG, but since u are swapping in an EK u will have to replace that one with the 99-00 SI. Thats probably why its not lining up wit the car cause you need to change that mount on top of the cam gears.
[Modified by civicrtype, 10:56 PM 3/20/2003]
LsScivic
07-11-2009 12:31 PM
