lower ball joint nut n screw stripped HELP!!!!!!
1 Post
I stripped the nut that connects the lower ball joint bolt to the castle nut that goes on it, an the castle nut is stripped as well... I honestly have no clue what to do, can i replace just that bolt an screw..?? do i have to replace the whole thing..?? anyone else have this problem..?? This is my daily driver so I can afford to not have a car for work an im tryna get this done ASAP..... help please...!!
1 Post
Re: lower ball joint nut n screw stripped HELP!!!!!! (mperezkr)
damn, i dont have time/money to bring my **** somewhere an have it pressed an all that.. from what i've read up an searched on it seems like everyone responds with "bring it somewhere to have pressed in" ect...... theres no way to knock out the old one an hammer in the new one..???
https://honda-tech.com/zerothread?id=1553878
and ur gonna have to get a new one pressed in i think, that or find some way to press it in. i dunno if thats safe tho
jus search it these are often problems in civics im sure theres plenty of info
https://honda-tech.com/zerothread?id=1465226
says you car hammer it in, if you realli dont want to rent the tool or dont have the cash
but its not gauranteed i would do it right the first time if you have the chance
Re: lower ball joint nut n screw stripped HELP!!!!!! (egcivic)
i took off the spindle, put it on a vice, got a socket just the right size and hammered out the ball joint. and vice-versa for installing
i would first try to rethread the ball joint and get a new castle nut. thats what i did when this happened to me
Re: lower ball joint nut n screw stripped HELP!!!!!! (JDM_SOHC)
bring it to a shop. my buddy didnt listen to me and lucky from him he has AAA and a messed up rim.
Re: lower ball joint nut n screw stripped HELP!!!!!! (Cyberdx16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyberdx16 »</TD></TR><TR><TD CLASS="quote">i would first try to rethread the ball joint and get a new castle nut. thats what i did when this happened to me
definately do this first. find out what the thread is and get a die. re thread it. go to the honda dealer and get another nut. they will probably have to order it but you can use a regular nut for the time being. the threads dont look TOO bad.
Re: lower ball joint nut n screw stripped HELP!!!!!! (TurboEM1)
If you can try to rethread it but I think you should just go ahead and replace it. And yes you can do it without having to press it in and out. Let me see if I can find you that thread......btw search is your friend...here's one of the many thread about your situation....
https://honda-tech.com/zerothread?id=1279654
Here's another one that might help you out....https://honda-tech.com/zerothread?id=1155081
1 Post
ok well i just got done doing lower ball joint, an new cv axle both on passengers side... now that infamous knocking noise that was occuring everytime i let off the gas while driving before i did the job is even LOUDER..!!! im stumped.... new axles, tie rods, ball joints, rotors, brakes, an tires balanced an it still every time i let off the gas while im driving goes KNOCK KNOCK KNOCK KNOCK KNOCK, than when i start back on the gas it goes away..... im starting to think crazy here, maybe where the cv goes into the tranny, the gears are messed up...??? could it be shocks...?? AHHHHHHHHHHHHHHHHHHHHHHHHH
Also to add, i've got the car jacked up on jackstands right now an when i accelerate then decel there is no noise, but since i dont have LSD i dont think both wheels should spin when i hit the gas cuz the passenger one doesnt, but when i free spin it with my hands i can kinda hear a faint knocking/rubbing noise... im so stumped man this sucks....
Juans_MX3
42
07-10-2021 04:38 PM
93(Civic)EG6
09-01-2007 08:06 PM
tuphatt
11
09-15-2004 12:10 AM
