Low RPM hesitation
Low RPM hesitation
Hey guys i am driving a 99 coupe with a D15B in it. i am getting a nasty low rpm hesitation.. you can acually feel the car holding back but its running fine.
so it clears up around 3000rpm....and its good there on up....what i did was sprayed some carb cleaner into the TB and its cleared it right up and ran like a million dollars.... ran good for about 3days now its doing it again.....so i used carb cleaner again........same thing running great.........i wanna know why its doin this so i can fix it cause its a pain in the ***........any help or insight will be greatly welcomed
thanks all in advance
Re: Low RPM hesitation (Blougheed)
use throttle body cleaner instead of carb cleaner and check your fuel pump and when was the last time you changed ur fuel filter?
JUN.
04-06-2008 09:31 AM
