problem with 2001 gsr!!
Old Apr 27, 2007 | 12:45 PM
88civic's Avatar
Default problem with 2001 gsr!!
i have no cels and the car drives and runs fine most of the time but every once and a while at highway speeds in 5 th gear at 3k the car will have no throttle response (still able to push down on throttle but nothing), shift to 4th and same thing, this will go away if i turn the car off and back on again while rolling, and will go away once i hit about 30 mph...i also have a high idle 80 % of the time like 1100 rpm the other 20% at about 800 rpm... and about 6k or so no power it will not pull like it used to...that's why i thought fuel so i replace fuel filter and fuel pump relay....but still same problem, i will run the TPS test this evening!!
also went over vacuum lines and all seem fine,
the car has only 20 k and is completely stock engine wise down to the Honda oil filter!!!
did search on tps and fuel related problems and found no help!
thanks for help!!!
Old Apr 27, 2007 | 01:08 PM
-Championship-'s Avatar
76.169.175.137
Default Re: problem with 2001 gsr!! (88civic)
check if you have the little light bulb on the CEL
ive heard that people remove them so it can be easier to sell
Old Apr 27, 2007 | 01:17 PM
98BabiGs-T's Avatar
Default Re: problem with 2001 gsr!! (-Championship-)
Let me see... if your throttle isn't working then maybe you should first check your throttle body? Also there is a DIY cleaning your IVAC or w/e... since your idle is off. I have no idea what I'm talking about.
Old Apr 27, 2007 | 01:22 PM
forumnoobie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88civic &raquo;</TD></TR><TR><TD CLASS="quote">runs fine most of the time but every once and a while at highway speeds in 5 th gear at 3k the car will have no throttle response (still able to push down on throttle but nothing), shift to 4th and same thing, this will go away if i turn the car off and back on again while rolling</TD></TR></TABLE>
wow..
I have the exact same problem. I have had to pull over on a crowded interstate twice to restart the car b/c complete loss of power (even though car is still running). No cel's either, also a 01 gsr.
Old Apr 27, 2007 | 02:36 PM
im_poor's Avatar
Default Re: problem with 2001 gsr!! (forumnoobie)
when you put the key to acc. does the cel light illuminate?
won't hurt to check the t-body cable as well.
Old Apr 27, 2007 | 04:03 PM
88civic's Avatar
Default Re: problem with 2001 gsr!! (im_poor)
yeah i have a cel light and also hooked up to snap on scanner to see what is going on nothing !!!lol
cable hmmm.... its not like the cable is not moving its like a boging feeling!!! but will check to be sure!
thats carzy the same problem same year and model...
Old Apr 27, 2007 | 09:33 PM
VTEC_PRODUCTION's Avatar
ALMOST sounds like ecu...
Old Apr 27, 2007 | 10:02 PM
1998b18c1's Avatar
i had the same problem today with a customers 01 ls, after testing found out to be the distributor internally shorting out. may or may not be problem but it worked for me today. are there any other prob's ur having....?
Old Apr 27, 2007 | 10:10 PM
98BabiGs-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88civic &raquo;</TD></TR><TR><TD CLASS="quote">yeah i have a cel light and also hooked up to snap on scanner to see what is going on nothing !!!lol
thats carzy the same problem same year and model... </TD></TR></TABLE>
Did you do the spark plug/wire check? Boging/backfire can be caused by a faulty wire/plug. There are many things that can also make your car bog... but your best friend is process of elimination.
Old Apr 28, 2007 | 02:04 AM
kauaiboy66's Avatar
I have the same year I hope that I don't have any probs
Old Apr 28, 2007 | 12:00 PM
88civic's Avatar
Default Re: problem with 2001 gsr!! (kauaiboy66)
i had a cel about a week or so go and it was VSS but when i checked the plug and reset the ecu it went a way!!! would that have anything to do with it??
i checked the plug wires and they all have good spark, pulled the cap and the points on the cap are slightly corroded and the rotor has a black spot on it ??? i will change these parts Monday and see if this helps...... any ideas about the VSS though?
Old Apr 29, 2007 | 08:00 PM
Try pulling your vss out (unpluging it) and plugging it back in, worked miracles for mine.
JUN.
Apr 6, 2008 09:31 AM
johnjohn072002
Jun 7, 2007 09:59 AM
suspendedHatch
Jun 4, 2005 02:25 PM
tai93si
Jan 21, 2004 05:01 PM
b18bEG
Nov 7, 2002 06:49 PM
