lost motion assemblies
Old 04-22-2007, 05:54 PM
geebs's Avatar
Default lost motion assemblies
anyone know the difference between the civic si/gsr/type r lost motion assemblies? they all have different part numbers.. they only difference i knew about was the older style small heads to the larger newer style heads
Old 04-24-2007, 02:51 PM
geebs's Avatar
Default Re: lost motion assemblies (geebs)
bump for an answer
Old 04-24-2007, 03:04 PM
YoungKadafi's Avatar
just get the one from your engine, since its only used for vtec, if you have a d series, get the one from the d16y8,
Old 04-24-2007, 03:42 PM
.I.Need.Money.'s Avatar
Assuming you have a B-series motor, I'd go with the GSR or ITR LMA's (larger surface). My buddy just sawpped out his second set of B16 LMA's that crapped out again. Or if you're on a budget, do the H22 LMA's with the washer trick.
Old 04-24-2007, 04:11 PM
ok, when it comes to LMA's, i dont have much experience, so what exactly are the symtoms of it failing? and does your engine require them?
Old 04-24-2007, 04:22 PM
civicracer1600's Avatar
Default Re: (YoungKadafi)
i have mixed and matched all three different part numbers into different engines and it doesn't seem to make any difference. the way to check them is to pull your valve cover and push down on the vtec cam follower (the middle one) in between each cylinders pair of valves. if it sticks down AT ALL or even if you think it may have it is probably bad. one thing i can tell you is that i have yet to find a bad set in a gsr so i always just get gsr ones for any motor i replace them in. i dont think that they actually get gummed up with crap or anything like that because i have never had any success cleaning them. I think they actually start to gall inside on the walls the plunger rides on. so basically cleaning them does no good.
Old 04-24-2007, 04:25 PM
somebody please tell me why the LMA's are important? i mean, my engine makes alot of wierd noises, and ive done a valve job a couple times, specs are pefect.
Old 04-24-2007, 04:34 PM
geebs's Avatar
i have a gsr head but it has three gsr lma's and im assuming 5 of the first gen b16a (smaller head) lma.. gsr and type r have diff part numbers but.. i know either should work.. i was just asking if there were any major differences between the gsr, type r, civic si..
Modified by geebs at 10:03 PM 4/24/2007
jasrams
Honda Civic (2001 - 2005)
13
01-03-2012 08:15 PM
dstappity
10-13-2008 06:30 PM
babyboyws6
04-12-2007 12:32 PM
BG-Teg
02-24-2007 04:03 PM
Blu5GLude
11-14-2001 06:07 AM
Quick Reply: lost motion assemblies
