lost motion assemblies
anyone know the difference between the civic si/gsr/type r lost motion assemblies? they all have different part numbers.. they only difference i knew about was the older style small heads to the larger newer style heads
Re: lost motion assemblies (geebs)
Assuming you have a B-series motor, I'd go with the GSR or ITR LMA's (larger surface). My buddy just sawpped out his second set of B16 LMA's that crapped out again. Or if you're on a budget, do the H22 LMA's with the washer trick.
Re: (YoungKadafi)
i have mixed and matched all three different part numbers into different engines and it doesn't seem to make any difference. the way to check them is to pull your valve cover and push down on the vtec cam follower (the middle one) in between each cylinders pair of valves. if it sticks down AT ALL or even if you think it may have it is probably bad. one thing i can tell you is that i have yet to find a bad set in a gsr so i always just get gsr ones for any motor i replace them in. i dont think that they actually get gummed up with crap or anything like that because i have never had any success cleaning them. I think they actually start to gall inside on the walls the plunger rides on. so basically cleaning them does no good.
Re: (YoungKadafi)
i have a gsr head but it has three gsr lma's and im assuming 5 of the first gen b16a (smaller head) lma.. gsr and type r have diff part numbers but.. i know either should work.. i was just asking if there were any major differences between the gsr, type r, civic si..
Modified by geebs at 10:03 PM 4/24/2007
babyboyws6
04-12-2007 12:32 PM
