Keep my z6 tranny on my d16y8 or swap in the y8 tranny
Old 06-03-2004, 07:54 PM
95civicSirCoupe's Avatar
Default Keep my z6 tranny on my d16y8 or swap in the y8 tranny
I swapped in my y8 motor a few weeks ago cause i soun a rod bearing in my z6. Should i keep my z6 tranny or should i just buy the y8 tranny? will there be in proformance gains from getting the y8 tranny ?
Old 06-03-2004, 07:56 PM
clm
clm's Avatar
Default Re: Keep my z6 tranny on my d16y8 or swap in the y8 tranny (95civicSirCoupe)
They're pretty much the same thing. Unless you find a Y8 transmission cheap and want to add an LSD, I don't think swapping one is worth it.
Old 06-03-2004, 08:16 PM
skip.two's Avatar
the two transmissions are practically identical, except that the Y8 tranny has steel shift forks, and the Z6 has aluminum shift forks. which makes it the better (stronger) tranny out of the two.
Old 06-03-2004, 08:17 PM
jdmsiR20's Avatar
Default Re: Keep my z6 tranny on my d16y8 or swap in the y8 tranny (clm)
yeah, it probably isn't worth any extra money. the z6 and y8 gear ratios are the same
only difference is that the y8 has a steel stamped one compared to a aluminum shift fork (better) one in the z6. that and possibly the mileage....
edit... ^beat me to it... (i had steel/aluminum backwards too )
Old 06-03-2004, 08:48 PM
BoostinEJ1's Avatar
Yea don't even bother with it, its all the same for the most part.
Old 06-03-2004, 08:50 PM
skip.two's Avatar
yea unless you you can sell your Z6 and buy a Y8 for the same price, i wouldnt bother with it.
just get a Y8 tranny when you really need a new tranny.
Old 06-04-2004, 05:23 AM
thanks H-T bros! thread is dead
Old 06-04-2004, 05:27 AM
93CivicSI's Avatar
Y8 has stronger shift forks (steel)
bunnyx
06-04-2008 03:05 AM
amej8
06-03-2008 01:15 PM
97spooncivic
02-01-2006 08:48 PM
H.A.R.T b16a1crx
11
09-11-2004 09:01 AM
ASHY-ELBOW
11-04-2003 12:36 PM
Quick Reply: Keep my z6 tranny on my d16y8 or swap in the y8 tranny
