Just put Type R cams in my JDM B16A, what should i do to TUNE it
I just put the cams in, I also did the valve adjustment to the stock spec. but the valve or the engine seem to be ticking abit loud. also it make lots of sound when i rev it up. I have DC SS 4-1 Header, VAFC, CAM GEAR (set at 0 now). also B&M Fuel Presss Regulator (set at 39-45 psi). Any suggestion what i should do it make it run smoother? also is the stock JDM B16A valves and spring good enough?
Re: Just put Type R cams in my JDM B16A, what should i do to TUNE it (power_civic)
how loud is the tickering? is it louder then norm? my motor is bone stock right now and it ticks so im assuming its normal(i know i need a vavle adjustment and redo my timing but im tooo damn lazy for it)......
to tune it.... every motor is pretty diff..... i suggest getting it on a dyno... it may cost alot of money but im pretty sure once its tuned thoose R cams will shine.....
1 Post
i have a similar set-up but with type-r valve train as well... no ticking here, maybe you might wanna check the rocker arms.
Re: Just put Type R cams in my JDM B16A, what should i do to TUNE it (DOHCtorTHRUST)
yeah, it ticking louder than b4, how do i check the rocker arm??? what's ur setting on the Type R cams?
[Modified by power_civic, 8:19 AM 9/25/2002]
jceltalentoso
01-27-2014 08:54 PM
