why is my engine knocking
Old Jun 29, 2004 | 01:38 PM
dsosa51's Avatar
Default why is my engine knocking
i got a 96 gsr motor i just recently took out the type r cams it had, and put back the stock ones. this morning i notice a knocking sound comming out the hood, so i pop the hood open and rev the engine and it was making a loud kncoking sound. what could it be?? could it be the cams install wrong or what ???? or something worst
Old Jun 29, 2004 | 01:41 PM
milo's Avatar
Default Re: why is my engine knocking (dsosa51)
did you adjust the valves?
Old Jun 29, 2004 | 01:42 PM
pbizzlegsr's Avatar
did you do a valve adjustment right after the stock cams were installed again?
Old Jun 30, 2004 | 05:54 AM
dsosa51's Avatar
Default Re: why is my engine knocking (pbizzlegsr)
i don't see why i need it if i replace the type r's with the stock gsr cams
and when i put the type r's in i did'nt get a valve ajustment and it ran fine for 3 months
Old Jun 30, 2004 | 07:18 AM
dip-set's Avatar
and after the three months?
Old Jun 30, 2004 | 07:22 AM
95 integra's Avatar
Default Re: why is my engine knocking (b18b-se)
A) You need to adjust you're valves EVEN IF YOU GO WITH A DIFFERENT SET OF GSR CAMS....the cams have worn differently then the ones that were in there and there for will need different adjustments.
B) Check your ignition timing(dont be lazy like you were with the valve adjustment, just do it).
C) Stop doing things the half *** way and do things the right way. I cant imagine why somebody would think its ok to put a different set of cams in and not do a valve adjustment, especially considering that you're suppose to do them every 30k anyway.
Old Jun 30, 2004 | 07:31 AM
95teggyls's Avatar
yes i agree totally ^
Old Jun 30, 2004 | 08:53 AM
DriveSideWays's Avatar
yuppers!
Old Jun 30, 2004 | 09:13 AM
Steak84SS's Avatar
Well my question would be, if the Type R cams ran fine for 3 months, why take them out?
Old Jun 30, 2004 | 09:18 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsosa51 &raquo;</TD></TR><TR><TD CLASS="quote">i don't see why i need it if i replace the type r's with the stock gsr cams
and when i put the type r's in i did'nt get a valve ajustment and it ran fine for 3 months</TD></TR></TABLE>
You shouldn't be working on Hondas.
Old Jun 30, 2004 | 09:55 AM
G-bonic's Avatar
Hijacked
might be some get away bolts or screw or any piece of ur head playing around inside ur head
jceltalentoso
Jan 27, 2014 08:54 PM
worx
Apr 26, 2012 04:57 AM
aut0tek
May 26, 2004 11:19 AM
sikcrx80
May 20, 2003 06:49 PM
migo
Nov 13, 2001 11:14 AM
