JDM DOHC ZC??
Old 08-22-2004, 06:52 PM
dryhopsux13's Avatar
Default JDM DOHC ZC??
i have a 96 coupe and i was wondering if i could easily swap a 92-95 dohc zc engine into my civic. I was also wondering how this motor handles under boost because i have a turbo set up ready to put on. ANY info is appreciated.
Old 08-22-2004, 07:14 PM
zcsol93's Avatar
Default Re: JDM DOHC ZC?? (dryhopsux)
hey man i have a 92-95 jdm zc in my car right now.. running hard revs out to 7500 without a problem with the right ecu.. im about to boost it as we speak but im sure they handle great many people have had sucess... (homemadeturbo and others... slap a d series kit and be on your way!!)
Old 08-22-2004, 07:15 PM
hatchling37's Avatar
You're going to have to do an OBD conversion, and I don't know what mounts you would use. Other than that, it should bolt up fairly painlessly. I don't think that it will handle a ton of boost in stock trim. I bet if you search, you can find what kind of c/r and boost handling you'll be looking at.
Old 08-23-2004, 08:20 PM
zcsol93's Avatar
Default Re: JDM DOHC ZC?? (hatchling37)
ull handle 10 psi no problem and even up to get a nice ball bearing turbo like apexi ihi and ull be straight... ill post number right after my install... also that is obd 1 so your straight...
Old 08-24-2004, 07:40 AM
Default Re: JDM DOHC ZC?? (zcsol93)
yea... i already have my car running obd1 so thats not a prblem. Also..... would i have to get custom motor mounts, or will everything swap stright up?
Old 08-24-2004, 05:44 PM
zcsol93's Avatar
its a straight swap but the axles/ intershaft are crazy.. have to hybrid them... i for get what we had to do with mine but its a mix of older integra and something else... reserach it... mounts drop right in though... make sure u change ecu though.. thing is high reving stock ull love it... who need vtec!
miniturbo
01-02-2004 08:25 PM
OutLuDeD
04-17-2003 10:31 AM
-=TWITCH=-
03-10-2002 12:15 PM
Quick Reply: JDM DOHC ZC??
