I nnned so COLD A/C... Can you help??
Old 05-28-2005, 11:17 AM
ronqqq's Avatar
Default I nnned so COLD A/C... Can you help??
1994 Civic
I bought a A/C compressor off Ebay,,
What else should I buy to make sure the A/C works correct...
"Drier" and what else?? Is there such thing a an A/C filter..
If there is where is it??
Thanks
Ron
Old 05-28-2005, 11:47 AM
ronqqq's Avatar
Default Re: I need some COLD A/C... Can you help??
Any One know wny thing about A/C units??
Old 05-28-2005, 02:20 PM
Hurricane's Avatar
Default Re: I nnned so COLD A/C... Can you help?? (ronqqq)
I think you gotta have a shop "vacumm dry" the system after it is all put together, I sure don't know how to go about getting them but new seals on the lines that were loose may be a good idea too (I may be wrong).
I only know a little about AC.
Old 05-28-2005, 03:18 PM
methos713's Avatar
bump...i need to know this too. Getting a/c for my car too.
Old 05-28-2005, 03:53 PM
Farmer Brown's Avatar
Wait. Your car does not have ac and you are adding it?
Old 05-28-2005, 04:34 PM
egtwincam's Avatar
make sure all the lines you buy are cleaned out. the receiver/ dryer needs to be new, all the other parts can be used. parts list is: condenser, compressor, evaporator, t-stat, receiver/dryer, all lines, pressure switch.. you should buy all new o-rings and coat it with pag oil and buy HOnda PAG oil for a shop to install it before they evacuate and recharge the system. good luck.
Old 05-28-2005, 04:45 PM
ronqqq's Avatar
Default Re: (egtwincam)
THANKS
tHAT Shuld help
Old 05-28-2005, 04:57 PM
athoughts's Avatar
Default Re: (ronqqq)
i have pretty much the whole ac system ive takin out of my 93 civic if your looking to spend some money
Old 05-29-2005, 01:36 AM
methos713's Avatar
what's a T-stat and isn't the reciever/drier the same as the evaportor...canister thing?
seantobin5
08-24-2012 05:50 AM
cocktails
Honda Civic (2001 - 2005)
03-24-2011 02:35 AM
tony413
08-31-2010 10:25 AM
NazVil86
09-20-2006 08:57 PM
mingbling96
05-11-2005 03:11 PM
Quick Reply: I nnned so COLD A/C... Can you help??
