I nnned so COLD A/C... Can you help??
1994 Civic
I bought a A/C compressor off Ebay,,
What else should I buy to make sure the A/C works correct...
"Drier" and what else?? Is there such thing a an A/C filter..
If there is where is it??
Thanks
Ron
Thanks
Ron
Re: I nnned so COLD A/C... Can you help?? (ronqqq)
I think you gotta have a shop "vacumm dry" the system after it is all put together, I sure don't know how to go about getting them but new seals on the lines that were loose may be a good idea too (I may be wrong).
I only know a little about AC.
make sure all the lines you buy are cleaned out. the receiver/ dryer needs to be new, all the other parts can be used. parts list is: condenser, compressor, evaporator, t-stat, receiver/dryer, all lines, pressure switch.. you should buy all new o-rings and coat it with pag oil and buy HOnda PAG oil for a shop to install it before they evacuate and recharge the system. good luck.
seantobin5
08-24-2012 05:50 AM
