i need blinker help!!!!!!!!!!!
i was trying to connect fast blinkers an now when i put my blinker on to go right my hazards come on an when i push the hazard button it doesnt work at all but when i put the blinker on to go left it works fine
as it sits now the stock flasher thing is plugged in an it does what i said above
its on a 93 del sol, an all my fuses under the hood an under the dash is good??? what do you think it can be???
you need to press rewind and start all over. Put everything back to where its stock if you can. if you can, if you can do that then be careful not to use the wrong connections where the flasher goes.
impo why would you want that anyway isnt that just a way to say your blinker light is out. looks trashy impo
Re: (Kevinarich)
yeah right now everything is back to stock but when i turn it on to go right my hazards comes on an when i turn the blinker on to go left it works fine an when i push the hazard button it doesnt do nothing
an i check all the fuses an they seem to be good, i was thinking it could be a relay but i have no clue were it can be
the only way this could happen is if you changed the wiring at the hazard switch. Or if your hazard switch is on and you have something messed up with your bulbs.
the blinker relay simply turns on and off power based on the load attached to it.
The turn stalk simply directs the pulsing power from the flasher relay.
The hazard switch directs the turn signal stalk power pulse to the right bulbs.
Re: (Relic1)
so you think i need to buy a nother hazard button because as of now everthing is stock the only other thing i messed with is doing independent fogs but i dont think that would have anything to do with that
Re: (EeeJayEight)
yeah i think i touched the wrong wires together a couple of times but the other times the fuse popped this time the fuse didnt pop this happen... is there a relay for the blinkers?? an if so were is it at??
Re: (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 »</TD></TR><TR><TD CLASS="quote">did you add blinker fluid?</TD></TR></TABLE>
Obviously not. How can he want fast blinkers and not put in fluid
Re: (poweredbysol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poweredbysol »</TD></TR><TR><TD CLASS="quote">yeah i think i touched the wrong wires together a couple of times but the other times the fuse popped this time the fuse didnt pop this happen... is there a relay for the blinkers?? an if so were is it at??</TD></TR></TABLE>
have you checked the fuse in the under hood fuse box?
you havent recently changed any bulbs on the passenger side of the car have you. when i got my old rex it did similar things only worse, turned out to be the wrong bulb. it fit in the socket but caused problems.
Motown Del Sol
09-06-2009 08:08 AM
5thGenFanatic
11-06-2006 10:32 AM
