I have a em1 how do I keep my original key when replacing my ignition
thank you thives... if anyone has the answer I would be most greatfull as my helms manual is pretty godamn confusing.
Re: (SpoolinEK9)
it looked faily simple I just turn the key to the 1 position and then pull the key housing out and then slide the new housing in turn the key back into the 1 position and you should hear a pop letting you know the lock is set into place.
You guys are talking about having the internals of the ignition changed.
Re: (137)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 »</TD></TR><TR><TD CLASS="quote">it looked faily simple I just turn the key to the 1 position and then pull the key housing out and then slide the new housing in turn the key back into the 1 position and you should hear a pop letting you know the lock is set into place.
You guys are talking about having the internals of the ignition changed. </TD></TR></TABLE>
i actually need to do that too, same situation, ****** thieves!
got a step by step?
got a step by step?
bfpicard
03-17-2014 07:44 AM
_Spugen_
14
01-17-2005 01:49 PM
liljohnson
08-12-2004 11:48 PM
wizzards581
12
12-11-2003 06:25 PM
