how to install shocks
New User
can anyone show meeh how to install shocks .. i jsut gotta swap my front ones because they are blown and drop my car just alitte bit more
Re: how to install shocks (JDMEK-)
bump
Pretty simple. Just unbolt the fork right behind the brakes. Unbolt the brake line from the stock shock, then unbolt the two nuts on top and it should drop right down.
it is pretty straight forward. u need the right tools. a lot of time to spare and patient. just unbold whatever's in the way to take off shocks and reinall the bolts/nuts back on. and done. normall take about hour and half if u use hand tool and all by yourself.
Cool Cool Island Breezes. BOY-EE
If you have stock springs, it may not be a bad idea to buy a spring compressor. You could also take the shock assembly out of the car completely. Take off the shock fork. Then put just the shock itself back on the car, and bolt on the top mounts. Undo the top 14mm nut while holding the shock piston in place with a 5mm allen key. Move your feet so they dont get smashed by flying shock/spring. That's how I roll. You should be able to put the assembly back together without a spring compressor. Use your guhhhrly arrrms....then GET TO ZE CHOPPA!!
Seach, though. They probably have pictorials and everything.
Re: how to install shocks (K20 INSIDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20 INSIDE »</TD></TR><TR><TD CLASS="quote">cheap spring compressor=2 guys and a towel</TD></TR></TABLE>
Or a jack and a strut tower.
You can always be ghetto and use a C-Clamp. lol....or just go with the two guys and the towel....maybe they'll block you right before a spring comes flying your way
Re: how to install shocks (twentytwocpb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twentytwocpb »</TD></TR><TR><TD CLASS="quote">....maybe they'll block you right before a spring comes flying your way </TD></TR></TABLE>
lol...caused my buddy $789.00 on his s14...
you can rent spring compressors for free at autozone. You pay a $50 deposit..then you return the tool and you get your $50 back.
Spring compressors are for little girls anyway lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twentytwocpb »</TD></TR><TR><TD CLASS="quote">lol yea i suggest if you go with the two peeps....then do it where there arent any nice cars around lol </TD></TR></TABLE>
It's not really a big deal i fyou point the shock at the ground. You leave it bolted in at the strut tower, and move it so it wont hit the LCA. Then just pop off the top nut. I did that method on my S2000...and it's a nice car. It's as black as wesley snipes.
Carp
04-03-2002 01:13 PM
d0nkeyxPunch
15
01-14-2002 10:01 AM
