installing shocks, need help[
Old Apr 6, 2002 | 11:28 AM
TexTeg's Avatar
Default installing shocks, need help[
Ok, I am about to install some KYB AGX's on a 1.8" drop. Is there anything I need to worry about? Or is this basically just put the springs on the shocks, put the shocks in the car? Thanks
Old Apr 6, 2002 | 01:35 PM
TexTeg's Avatar
Default Re: installing shocks, need help[ (TexTeg)
Anyone? Please
ttt
Old Apr 6, 2002 | 01:50 PM
GSRaCeRbOI's Avatar
doesnt KYB void your warranty if its lowered more than 1.5"? or was that Tokico blues I forget.... anyway as for the install bolt off the old spring/shock then compress the spring, use a hex key to hold the middle shock rod while turning the top nut (w/ spring compressed) i think the top nut is 14 mm and the hex key is something like 5mm? (this is all from memory) then unbolt the top cap, uncompress and remove the stock spring, and take out all the washers, bushings, dust boot, etc.. noting their order so u can re-apply them on the KYBs.. and then put the lowering springs on the KYB shocks and follow the diagram/instructions that KYB supplied.. You'll need to re-use some parts like the bump stop, dustboot, ID spindle, bushings, top shock cap, etc... and KYB supplies the top nut and a collar... installations pretty much the same as my Koni's..except Koni supplied new ID sleeves/spindles, washers, etc..
Old Apr 6, 2002 | 02:23 PM
I Drive A Saturn's Avatar
Default Re: installing shocks, need help[ (GSRaCeRbOI)
yep and don't forget to set the AGXs to their softest setting for easier install
-jeremy
Old Apr 6, 2002 | 04:20 PM
TexTeg's Avatar
Excellent. Thanks a lot. And yes, KYB voids the warranty if the drop is more than 1.3", but this car isn't going to stick around for more than 4 years and I feel confident they will last at least that long (seeing as 1.3" or less is a lifetime warranty).
Do I have to cut the bump stop at all or keep it whole? This install doesn't seem too difficult... If you can install springs on your own, you can install shocks (or so it would seem...).
notsoslow
Suspension & Brakes
May 26, 2009 04:13 AM
JDMEK-
11
Jan 8, 2008 11:01 AM
Midori Green
12
Aug 18, 2007 09:50 PM
tianporn
Nov 30, 2004 08:55 PM
