HOw important is the crank fluctuation sensor? Got the code this morning.
Re: HOw important is the crank fluctuation sensor? Got the code this morning. (Spade)
Yes it is under the crank pully in OBD2 engines. Important enough that the OBD2 ecu requires the signal.
Re: HOw important is the crank fluctuation sensor? Got the code this morning. (SLPR)
When i first did my swap....i forgot to connect that and it would turn on but wouldnt stay on unless i would give it gas....my opinion...VERY IMPORTANT!
1 Post
I had that code for a little bit after I pulled my motor for the first time (then put it back in). The timing belt rubbed a hole in the wire and cut through a few of the wires..
It's not the kind of code that will make your car run any different, but that cel is really annoying.
Re: HOw important is the crank fluctuation sensor? Got the code this morning. (fowler)
I am taking into the shop that just replaced the engine today. But, damn. This car is getting irritating.
More and more I want to trade the thing in.
Acehonda
01-31-2005 02:32 PM
scoobyghost
06-19-2004 12:21 PM
