Code 54 Crank Fluctuation Sensor questions
You swap guys might be able to help me with this one. I just pulled a code 54 on a 99 civic ex and have two questions. First where is the sensor located and second could this be cuased by something else. The persons car cranks up real slow. Any help would be appreciated.
Re: Code 54 Crank Fluctuation Sensor questions (scoobyghost)
My car was cranking slowly. Turned out that the guys who put my engine in didn't tighten the bolts holding the starter in.
Re: (Shaun)
What did you do when you had this code...btw i didn't do a swap i just thought that this was a more common issue in the cars who have had swaps
the sensor I through a code for is located right behind the crank pully , I didnt plug it up becuase the wire was cut on my b16 swap that I bought, the reason I didnt fix the sensor is because I converted to OBD 1, all it did when I had this code was throw the CEL
