How does the starter spin the motor
Is it connected to a belt, that spins something. or directly to the crankshaft. and where is it?
Re: How does the starter spin the motor (drumminforev)
The starter spins the crankshaft via the flywheel. The teeth along the outside edge of the flywheel are engaged by the starter and disnegaged when you let go of the key.
The starter is located near where the transmisson and the engine bolt up, depending on the drivetrain, is attached to either the transmission or the engine block.
Re: How does the starter spin the motor (L8apex)
thanks, makes sense where there's a huge hole in the side of my trannin sittin here. So does that gear with the teeth pop out to engage and slide backin when its done cranking?
Re: How does the starter spin the motor (.Red.EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 »</TD></TR><TR><TD CLASS="quote">You post threads like this and don't know where the starter is or how it works?
Wow.</TD></TR></TABLE>
At least he's humble enough to ask a question that he doesn't know about rather than just acting like he knows.
Killer fro by the way
Re: How does the starter spin the motor (EJ1 wilcox)
Yes sir, I am just beginning to really learn cars. But i know my a/c ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">At least he's humble enough to ask a question that he doesn't know about rather than just acting like he knows.
Killer fro by the way </TD></TR></TABLE>
Definitely.
Definitely.
I'm not knocking a guy for wanting to learn. I just figured if he knew his stuff about HVAC, then he should have known.
But for wanting to learn.
