Engine Grind
Old Nov 29, 2004 | 04:12 AM
kdscott23's Avatar
Default Engine Grind
I have a 1990 Civic Hatch, went to start it this morn.....would not turn over.....engine would just grind as if turning the key when its already running......i gave it a few mins....same thing...any ideas.....low oil? starter?
Old Nov 29, 2004 | 04:16 AM
chris_c's Avatar
Default Re: Engine Grind (kdscott23)
starter not engaging properly with flywheel. it is either the starter [gear in nose not driving out far enough] or a bad section on the teeth of the flywheel.
yank the starter and check it out...
Old Nov 29, 2004 | 04:21 AM
eL's Avatar
eL
Yes I agree with Chris C, sounds like a starter problem.
Old Nov 29, 2004 | 04:23 AM
kdscott23's Avatar
Default Re: Engine Grind (chris c)
initially it did engage...a couple of chugs and it was out.....so it does sound like i've blown the starter?
Old Nov 29, 2004 | 04:35 AM
lohatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kdscott23 &raquo;</TD></TR><TR><TD CLASS="quote">so it does sound like i've blown the starter?</TD></TR></TABLE>
yep, if you are in a hurry and need to get somewhere put your car in nuetral and get it rolling and hop in and pop the clutch. park it in a place where you can do it again when you leave
dmanfree
Jun 21, 2013 12:38 PM
dominate9
Jan 16, 2009 04:32 AM
h22a_black
Feb 13, 2008 06:12 AM
383chevy
Jan 25, 2007 07:58 PM
classciv
Dec 18, 2005 11:53 AM
