antenna install on em1?
ok so here is the deal, i pulled the old antenna out, now im stuck as to find a way to fish the new antenna through the hole. is there any trick to this or what? i already searched really couldnt find anything. thanks in advance.
Re: antenna install on em1? (bunks99si)
It wouldve helped if you had tied a string around the old one before you pulled it out.
Just snake it down the a-pillar under the dash and plug it into your sub lead.
You're on your own with this one.
Imperious: Mod of Valor
Re: antenna install on em1? (Echo7847)
It's going to be a real pain to do. My best advice is to just snake it down there and attack it to the plug in.. Good luck.
this is what i did.
get an antenna block off plate.
install the antenna to the radio, and find a place behind the dash to hide it.
i did mine like that in my ej1, and i still pick up my radio signals fine. just cover all metal pieces up in the antenna with electric tape or whatever to keep from haveing road noise.
i took an old fish tape thingy and chopped off the hook on the end. then i just pushed it up from under my dash and was able to pull the antenna back down. wasnt too hard lol
austinwith96civic
03-11-2010 09:49 AM
bmw626
06-06-2005 02:49 PM
