how do i get rid of that annoying beeping noise?
Re: how do i get rid of that annoying beeping noise? (jintek)
There is a fuse you can take out...however as annoying as it is right now, you WILL miss it that time you leave your keys in the ignition I did the same thing for a while....hated it.
1 Post
Re: how do i get rid of that annoying beeping noise? (Kamin)
I think it disables the beeping too. For some reason, I disconnected it on my old car and never heard that beeping again. The seatbelt light never showed up either...
Re: how do i get rid of that annoying beeping noise? (fowler)
theres a how to for this posted a few days ago. very easy steps, but i need pics to explain it. search terms like "key remove buzzer" or something like that. i totally forgot.
krazy
krazy
on my car if you turn the ignition to the on position instead of the acc position, it stops beeping with the door open after a couple seconds.
Re: how do i get rid of that annoying beeping noise? (tominos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos »</TD></TR><TR><TD CLASS="quote">on my car if you turn the ignition to the on position instead of the acc position, it stops beeping with the door open after a couple seconds.</TD></TR></TABLE>
as with every car....but you are going to kill your battery if you leave it like that.
Re: how do i get rid of that annoying beeping noise? (EG CoUpe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG CoUpe »</TD></TR><TR><TD CLASS="quote">There is a fuse you can take out...however as annoying as it is right now, you WILL miss it that time you leave your keys in the ignition I did the same thing for a while....hated it.</TD></TR></TABLE>
exactly!
exactly!
spencedogg
03-07-2003 11:33 PM
