How difficult is it to install a new ignition?
Well i'm sure you all know what it looks like when someone tries to steal ya honda. My ignition is all busted and i wanna replace it ASAP. I wanna know is it really hard to do it yourself or would i be better off going to the dealer. Also, I wanna know can i change the lock core. I'd like to keep my original keys but if i gotta change it with the ignition, I gotta change it with the ignition. Thanks for your help in advance
Re: How difficult is it to install a new ignition? (phanatic)
its easy. just cut the tab on the top of your steering column where the old is attached, then go buy a new one at dealership (100+ bucks) you can either switch out your key cylinder (so you can use the same key) and just screw it on the steering column, the bolts will snap off as it tightens down.
formerly DxHatchback
Re: How difficult is it to install a new ignition? (cxSHOE)
he could also find someone parting out a wrecked honda to save money (as long as they have the original keys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">its easy. just cut the tab on the top of your steering column where the old is attached, then go buy a new one at dealership (100+ bucks) you can either switch out your key cylinder (so you can use the same key) and just screw it on the steering column, the bolts will snap off as it tightens down.</TD></TR></TABLE>
Re: How difficult is it to install a new ignition? (DxHatchback)
It's always best to buy a new one. I just bought one off of majestic honda online. It cost me about $230. But mine just completely went out. On the longrun, it's best to spend what the thing is worth than to keep on buying **** for half the price.
It's not hard to put it on either....It's all common sense.
Anything else...let me know
Man thanks for all the help. I'm trying to get my engine next and then a really good security system, quick release steering wheel, and some suspension stuff done.
allenhogans
07-26-2017 05:20 AM
rugimpy
08-21-2012 10:12 AM
The Collin
05-09-2009 06:20 AM
wuhungsixxx
04-08-2002 03:54 PM
