how to on changing axles?
Re: how to on changing axles? (King Tut33)
I am too damn good to you. First post in the FAQ thread:
https://honda-tech.com/zerothread?id=382416
Re: how to on changing axles? (TeamNextGenChris)
put front on jackstands. remove wheels. unbolt the balljoints for the steering rack and LCA. ball joint puller helps. unbolt axle nut (36mm or 1 1/4" 6 point socket). pull suspension away from axle. you may need to hit it with some wd40 and a hammer. once thats off just pull it out of the tranny, you may need a pry bar. there your done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 »</TD></TR><TR><TD CLASS="quote">I am too damn good to you. First post in the FAQ thread:
https://honda-tech.com/zerothread?id=382416</TD></TR></TABLE>
you beat me to it
you beat me to it
