horn doesnt honk!!!!
i have a 92 civic cx, and my honk doesnt work. i was hoping you guys could help me out, i have no clue where to start looking so any advice would be great!
Re: horn doesnt honk!!!! (b16a93cx)
Is your srs light on? Cause if it is it is most likely your cable reel. They are on the same relay and I have the same problem as you.
Re: horn doesnt honk!!!! (brucee)
nope no srs light....
My horn didn't work either but I could hear the clicking noise from the relay. It turned out it was the wiring to the horn itself had coroded. I just needed to cut the first six inches and hook up new wires.
check the horn fuse ?
under teh dash i think |
Well for a quick fix learn to Yell really loud, or go buy a Air Horn!! https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images...s/emsmilep.gif
Mine didnt work so i yanked it off!
Re: (blaster834)
mine doesnt work either https://honda-tech.com/forums/images/smilies/emsad.gif
Re: (ironcheftony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony »</TD></TR><TR><TD CLASS="quote">check the horn fuse ?
under teh dash i think</TD></TR></TABLE> the horn fuse Is under the hood in your engines fures box 20amp fuse should be yellow, if that fuse is blown your brake lights will also not work... |
Re: (92 civic VX B18c)
checked the fuses right now anything else???
put power straight from your battery to the horn if it doesnt work, bad horn. work your way back from there for power to ground causing a short. if you have to pass inspection or something wire it to your own swith to bypass all your other possible bad connections.
purposly disabled the horn .. i like playing with the horn buttons while driving lol
it is possible it might be the horn relay which in on the upper right side of the under dash fuse box. I dont remember the color of the wire off the top of my head, but if you ground one of them, the horn should work. Gt a test light and check it out. I tore my cable reel accidentally and my horn stopped working. I had another cable reel sitting around and popped it in and I have my horn back.
check the ground, 75% of the time the ground has come loose and just need to be re-attached or tightened.
Re: (MichaelJComputer)
I have one of this big loud, I think they are air horns in my ride. I hated the weak sound of the stockers. It's also pretty easy to wire up your horn. |
