Honda Civic 97 AC PROBLEM... HELP!!!
My ac was working fine but yesterday my radio was stolen and now the ac is not even blowing any air, the compressor is doing nothing. I have checked all of the fuses (the ones under the hood and the ones under the dash) but none of them were blown. The ac switch light wont come on but all of the others switches light work just fine. I think it has something to do with the cables behind the climate control because before the radio got ripped from the car everything was working fine.
Any help would be appreciated... thanks
Re: Honda Civic 97 AC PROBLEM... HELP!!!
the thing is none of the cables are cut and all of the switches turn on (direction of the air switches) except the ac one. i checked all the cables none of them were cut.
does your blower motor work in any of the fan speed settings? and about the a/c, id double check the wiring to make sure that none are damaged in any way. if you have a power probe, get to the connector on the compressor housing, unplug the harness, and manually power the compressor clutch to see if it engages. if to does, you probably have a wiring issue somewhere, or a bad switch, etc
