Honda Civic 95 TPS EACV issues
Hello Guys.
My Ej1 has a little electric problem with those 2 sensors..
1 TPS:
with the car running when i loose the throttle the RPM Drops fast instead of falling smooth. this symptom desapear if u disconect the TPS or Ajust the TPS more than Spec (above 0.5v) i have tried 3 tps and the symptom is the same.
2 EACV:
Simple the EAVC is not open correctly (very low air) and some times the idle oscillates i also clean and replaces valves (2 at the moment) and is the same
my car does not hav Any CEL and all is working good, except vibration when the AC is On due to low idle..
any idea of how can test, fix those problems?
1 TPS:
2 EACV:
