hmmmm
hmmmm
checked my CEL tonight and i have code 10 it says on here its for the iat sensor
but mine is fine... anyone know if the how to is wrong? i could of swore on the diy
before the current one codes 8 and 10 were different. also my speedomoter has been acting up. this started while it was raining so i figured the plug was wet, and
it was so i dried it out and it worked fine... today i drive to my grandparents
andeverything is fine, i go to leave and now my spedo isnt working. i checked the
plug again, it is dry but im not sure, i think the middle prong is broke... anyone happen to know how much a vss is for a b series or if i even need to buy a new one ( i really need help on this one fellas, hittin 2 step in ALL gears now ) any help greatly appreciated
Re: hmmmm (egmatt93)
vss for a b can be bought at a honda dealer, they have two versions, I think one lists for around 80-100$(us) and the other was around 150$(us) either will work
also check the wiring harness(engine harness) plug for corrosion, if it is corroded clean it out with some contact cleaner and grease it with some dielectric grease
