high rpm code 43 and 22
Old 10-29-2006, 01:11 PM
blk92hatchsi's Avatar
Default high rpm code 43 and 22
i have a 92 civic hatchback si with the stock z6. it has intake, mild headwork, header, and exhaust. when i get around 6 grand or higher in second gear and shift into third fast the CEL comes on. i checked the codes and it was 43(fuel supply system) and 22(oil pressure switch). when i turn the key off and back on it gos away.
when i bought the car a week ago the kid told me in need a vtec silenoid and i had one laying around that i knew worked so i put it on and didnt make any diffrence.
i was reading about code 43 and put a fuel pressure gauge on to check the fpr becouse it was easyist to check and it was fine.
the car dosnt run bad i just dont know why it would throw code 43 and 22 at the same time and both go away when i shut off the car. should i try taking the neg off the battery sence i changed the whole silenoid and pressure switch and if so whould it have anything to do with the fuel supply system cel at all?
ennohohbee
12-23-2013 02:05 PM
saintbhts
06-12-2013 09:43 PM
Thizzed Out
03-29-2009 05:09 AM
blk92hatchsi
11-14-2006 09:58 PM
97AccordCD5
12-13-2004 01:22 PM
Quick Reply: high rpm code 43 and 22
