Cel code questions
Old Dec 23, 2013 | 08:05 AM
ennohohbee's Avatar
Default Cel code questions
I got two codes my 95 gsr is throwing....The swap is in a 93 civic ex
It only throws these codes when i accelerate hard and Vtec pops
First code is 22 Which is Vtec pressure switch...What could the problem with my pressure switch be?...because vtec still engages but it engages a little late (6k) and the ecu is a stock ecu
2nd code is code 43 which is Fuel System Supply
What do i need to check here?
The car seems to run rich :S
Any help would be appreciated guys... Thanks
Old Dec 23, 2013 | 02:05 PM
fcm's Avatar
fcm
Old Fart
Default Re: Cel code questions
Replace Vtec pressure switch, sounds like it is going bad.
For code 43 replace fuel filter and check fuel pressure.
For the rich A/F ratio, check the ECT sensor, more so if cold starting is easy but so easy when engine at running temp. 94
saintbhts
Jun 12, 2013 09:43 PM
wrxya33
Jul 6, 2007 08:16 AM
turboH22Aakkord
May 22, 2006 10:31 AM
aleminx
Feb 18, 2006 07:25 AM
