High idling during stop
I got an 96 Civic Auto
no swaps, no CEL, nada
Completely stock
Whenever I start my car, it idles high, than goes normal, than high again
Whenever I park my car, it idles high and stays there
anyone know the issue?
3 weeks ago, I had a blown HG.. got a local shop to fix it for me. I can't remember if it did that before, but I doubt it. \
Anyone got suggestions on what it is?
Completely stock
Re: High idling during stop
Second on the vacuum leaks, if the car was apart its a high possibility. You can check with starting fluid. when you spray it on the area with the leak your idle will go up for a sec.
Personally I would take it back to the shop and tell them to fcking fix it
well i did take it back to the shop.. but i might not want too.. cuz i left the shop with my car running, but.. the drivers head light didn't work and my dipstick tube was out of the guiding of the timing belt covers
and i took it 2 times for 2 problems that they more than likely caused, so a 3rd time.. im kinda iffy, even though a lot of my friends and family go to them all the time
On ur intake manifold adjust the screw thats like right next to the with a flat head while ur car is on, set it to like 900rpm, atleast that what i have it set too, and its fine! THE GREEN CIRCLE IS THE IDLE ADJUST SCREW
I agree except fot the shop part. Check it with starting fluid/brake clean/carb cleaner. Thorougly spray down the intake manifold, all vacuum lines, and throttle body. DO NOT spray the alternator.
1 Post
You can alternatively just run a small propane torch (with the gas on a little but no flame) slowly over all of the vacuum lines. If the idle goes up for a moment you know that the area being tested has a leak.
im such a noob at this..
the vacuum lines, which ones are they? im really a visual learner, but i'll go get on that vacuum check right now.. gotta hit up checkers first for that carb spray
1 Post
Vacuum lines look kinda like coolant lines but have no coolant in them. Black tubes of varying diamante that go to places where coolant is not wanted. Like the break booster and the air intake.They are smaller than the big radiator hoses.
it may not even be a vacuum line. Since they had the car appart for the head gasket it could be an intake manifold gasket etc. Who knows what all they took off
xxvinxx43
10
09-05-2011 05:50 PM
Swish7
08-01-2007 06:31 AM
Anthony1
07-05-2006 07:25 AM
