High Idle (CEL code #4)
Old Jan 14, 2004 | 02:22 PM
gsr2jdm's Avatar
Default High Idle (CEL code #4)
Started up car and now it has high idle. Checked Ecu and I am getting code #4 which is for the crank sensor, i check the resistance and got a little over 350 ohms. Now could a misaligned timming belt cause this or is there anything else. I am going to try to do my timming belt and see what happens but I was wondering if there could be anything else.
I pretty sure its the belt off a little bit but was wondering if anyone else came across this problem ever...
95 Integra W/ B18c1
Old Jan 14, 2004 | 04:42 PM
rated_r's Avatar
Default Re: High Idle (gsr2jdm)
if timing was off it wouldnt case the car to idle high...
Old Jan 14, 2004 | 05:13 PM
gsr2jdm's Avatar
alright checked timing belt and had 2 people look at it (so its perfect). Now the only problem is that the car starts jumps to 2k then suddenly dies..
any ideas??
Old Jan 14, 2004 | 07:27 PM
gsr98teg's Avatar
does the car completely die or does it just go to a very low idle and then hop back up to like 2 grand??
Old Jan 14, 2004 | 08:16 PM
gsr2jdm's Avatar
Default Re: High Idle (gsr98teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr98teg &raquo;</TD></TR><TR><TD CLASS="quote">does the car completely die or does it just go to a very low idle and then hop back up to like 2 grand??</TD></TR></TABLE>
No, but i did lower my idle with the screw on the throttle body. So, if it were in the same position i think it might hold and run for a little bit more...
Old Jan 15, 2004 | 08:52 AM
gsr98teg's Avatar
a friend of mine had what seems to be the same problem with his car
he hada 94 4 door gsr and when it started to happen we looked at it and came to the coomclusion that it might have been his TPS check that and also that all ur vaccuum hoses are properly fitted
BTW he got a new throttle body with all the sensons included and it took care of the problem
Old Jan 15, 2004 | 09:30 AM
gsr2jdm's Avatar
i'm gonna check and see if i'm gettin any gas to the fuel filter and try to check if theres any way to test throttle body
mouab18c1
Aug 25, 2007 12:46 AM
zccrx
Jan 9, 2007 09:37 AM
coot_er
Oct 1, 2005 09:58 AM
stoopid_monkey
Apr 26, 2005 11:22 PM
Luke J
Apr 13, 2003 06:05 PM
