CEL code: P505 Idle Control Sys Malfunction.. possible problems?
Old Sep 15, 2002 | 09:12 AM
Integra_Boi's Avatar
New User
Default CEL code: P505 Idle Control Sys Malfunction.. possible problems?
after installing the skunk2 manifold.. i've been getting a check engine light with CEL code: P505 Idle Control Sys Malfunction.. what could be the problem. .i dont think its a vacuum leak because i sprayed gum cutter all over teh place.. and took teh manifold off once to see if there are any leaks and did it again... thanks in advance
Old Sep 17, 2002 | 02:51 AM
New User
Default Re: CEL code: P505 Idle Control Sys Malfunction.. possible problems? (Integra_Boi)
anyone?
Old Sep 17, 2002 | 08:57 AM
smkngsr's Avatar
check all ur vacuum...those pcv valves...just T them up...and reset the battery and that should be ok...if not lemme know the reason ur getting that cel is because u might have connected something that is not supposed to be there...double check to make sure...i did mine and theres was no problem at all..im pretty sure urs should be same as mine...hope this helpls...
Old Sep 17, 2002 | 11:55 AM
New User
Default Re: CEL code: P505 Idle Control Sys Malfunction.. possible problems? (smkngsr)
i was thinking maybe the iac motor? or the fast idle sensor?
89crxsi89
Mar 20, 2010 11:39 PM
zero708970
24
Jan 25, 2010 09:08 AM
boostedjdmdc2
19
Jan 7, 2008 06:25 PM
jewpont
13
Dec 18, 2007 07:54 AM
piotrush
Oct 7, 2006 01:38 PM
