high idle b16a
high idle b16a
After installing a frankenstein b16a in a 99 civic hx, the motor idles at 3200 rpm. If I remove the MAP sensor it drops to 2000 rpm. The block is a CRV with a JDM SI head and a GSR intake manifold. Any help will be appreciated. Thanks.
Re: high idle b16a (jessej)
make sure you don't have your tps and map sensors plugged into eachother. they have the same plug style
Re: high idle b16a (jdmeg9)
Just went and double checked. They are plugged up right, but the throttle body came off an automatic. I've heard there is a difference in the tps between an automatic and a manual. Do you know? I appreciate the reply.
Re: high idle b16a (Sleek98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleek98 »</TD></TR><TR><TD CLASS="quote">how can a gsr intake manifold fit onto a b16 head? the bolt pattern is different. this might be your problem</TD></TR></TABLE>
exactly so you don't have gsr mani period
is the the tb gasket on backwards?
check for vaccum leaks
