Help on which TB for B16 Edelbrock Victor X?
I searched a lot and still didnt figure it out. I just picked up the B16 Victor X and im not sure which TB to use. Edelbrock only has them for the B18C1 or C5 and i want to make sure im getting the right one. I would think the C5 because the IM has the provision for the FITV on the manifold itself but im not sure if the C5 has it on the TB or not.
Any help is appreciated!
Thanks
BTW: Im using this on a odd setup so im not familiar with the newer TB's so thats why im asking. My car has the FITV and IAC on the IM itself.
Thanks
Re: Help on which TB for B16 Edelbrock Victor X? (RobT5580)
The PN 4789 (B18C5) throttle body is also a direct bolt on for the 1999-2000 Honda Civic Si w/ B16A motor. The B18C5 and B16A use the same cylinder head and similar intake manifolds. They use the same Victor X manifold, 4764/4765. Some adjustment of the throttle stop screw and/or idle bleed screw may be required to obtain the factory idle, but it's in the instruction sheet.
CRXguy_88
08-08-2011 06:18 PM
lmiguelvv
31
08-29-2005 05:25 PM
crexer
02-12-2005 10:40 PM
