help rattle when i start
hey ive got a b16 with about 70k on it. when it sits over night the, past 3 nights, and i go to start it in the morning i get a rattle from within the motor that last for about 3 seconds!!!! im worried what this may be. i searched and all i found was crap. please help if you have any idea what it could be
Re: help rattle when i start (bleedblue94)
mine did this, and i couldnt find it! until a brace from my header fell off....
a bolt was loose on a header support mount if you will.
it would only shake at start up, cuz my engine idles a little low when it has sat and cooled down.
anything can rattle, so its hard to say
Re: (2FAST4U831)
well im thinking valves bc im burning oil and and smoking alittle but i just had a valve job done last year and i dont really beat on it all that much
Re: (bleedblue94)
cars do smoke a little more when they are cold.....if you just had the valves done then they should be fine.
i dont see how valves would rattle for only 30 seconds.
i dunno
im not a very good e-mechanic
i dunno
All Motor Mentor
1 Post
Re: (bleedblue94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">5w - 30 i believe its a rod knocking </TD></TR></TABLE>
possibly....sometimes it's in the valvetrain (LMA's) that require oil pressure to "take up the slack". Does the rattle sound "deep" like a "rapping" noise inside the engine or is it more of a ticking noise?
Re: (00Red_SiR)
Im new to hondas it sounds like a timing chain, but i doubt that thats what it is since honda uses belts.
Second guess I would say it sounds like you will be bringing back the car for the valves .. unfortunately, unless they botched the job up ... then yea, 00Red_SiR would be right ... and defintely rod knocking -- but you say rattle? is it more like a clunk-knock type of noise?
Re: (00Red_SiR)
its sounds like 5 pennys in a coffe can being shook around only its slightly lower tone
i was listening to the motor and it sounds like its coming from the block
swapped95
19
09-30-2007 06:29 PM
Ghostyman
09-12-2005 08:42 PM
