help plz, 94 coupe/5-speed d15b with high idle
Ok so I got a 94 coupe with a 5 speed d15b..
I just got the car last Sunday and hadn't had a problem with it until tonight.
I got off school @ 10 pm, turned on my. Car, and since my stereo doesn't work I put on my headphones and turned on my ipod..
I waited like 30 seconds which I know is not right but I was tired so I took off...everything was fine, I drove about 5 miles to the freeway..when I got on I srarted stepping on the pedal and shifting @ high RPMs
When I got off the freeway I pushed in the clutch to put it into neutral and noticed that my car was idling and not to low rpms but up to the 4 and 5 thousand so anyways I somehow made it home, when I got home I noticed that when I. Try to pull out my gas pedal it doesn't idle, its like the pedal is kinda stuck in....anyone ever had a problem like this??
Plz help, thanks in advance
Re: help plz, high idle problem
i've had that problem with my gsr in my eg. when i floor it the pedal gets stuck. i just pull it out with the tip of my shoe.. its the throttle cable at the throttle body. needs to be tightened
So I woke up early today (6 am) even tho I don't go into work till 9 to check out my car, I checked the throttle cable like u guys said and it wasn't loose or dirty but I did notice a small ring like object around the cable, sorta looked like a little nut, maybe like 5/8 or something....but wat I'm guessing is that when I stepped on the pedal that nut got stuck causing my cable to stay open....
I got sat and sun off so ima take more time to check out wats wrong..
But yea thanks for the help guys, appreciate it
b16jose
09-21-2011 04:45 AM
pine_apple45
11
08-12-2007 11:00 PM
