Help with my 00 si coupe
Help with my 00 si coupe.. RPM/engine problem
for some reason, my car RPM is goes below 1000 on idle. when i gas then let it idle, it seems like the engine is about to die, then it slowly pick up power again. Anyone got any answer to this? THanks!!!!
Re: Help with my 00 si coupe.. RPM/engine problem (paowa)
my si used to sit around 700 as well...the gsx i used to have the same problem, when u give it gas and then let go, it went way down and sputtered and them shot back up, i believe the problem was something with the fuel pump or fuel filter, also check your vac lines-Shift
Modified by djshift at 10:44 PM 1/29/2007
jermo
42
10-26-2010 03:23 AM
Insane Si Lum
02-08-2006 02:14 PM
Milano00Si
16
02-28-2005 10:45 AM
