help me!
Old 08-06-2003, 08:19 PM
projectEK9's Avatar
Default help me!
originally put in tech section........I took out my oem intake pipe a while ago, and the cel light happened to pop on, thinking this was the sensor that hooked onto the pipe, I didnt think much of it....I just installed a cai on my car, and when I unhooked the battery to reset the ecu, the light went off....then came back on......my friend told me about checking the code by myself...which i did....the light blinked once..... meaning...."Open or short in O2 sensor circuit, defective Primary O2 sensor" WHAT DOES THIS MEAN? Do i need a new o2 sensor? Im open to all comments and suggestion...thanks guys....
Old 08-06-2003, 08:26 PM
Global Moderator
Jimmy's Avatar
Default Re: help me! (projectEK9)
pull the ecu fuse for like 10 mins..then put it in and let it idle for like 10 mins and it should fix it...
Old 08-06-2003, 10:55 PM
projectEK9's Avatar
Default Re: help me! (USDMDC2)
Just did what you told me to....same thing is happening...........whats goin on...hmmmmm......anybody else.?
Old 08-17-2003, 04:29 PM
projectEK9's Avatar
just installed a new sensor.....cel code stayed on after resetting the ECU/ dc the battery.....what do I do now? all the wires look good......my car was idling like crazy today....car died 4 times today when I was rolling up to a red light.....does anybody know how much a primary o2 sensor would cost at the dealership?
Old 08-17-2003, 04:49 PM
Terry.Ho's Avatar
I got a bosch replacement sensor with the plug for $90. What motor do you have? It sounds more like a Idle Air Control valve to me.
Old 08-17-2003, 05:26 PM
New User
Mr. Choi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 &raquo;</TD></TR><TR><TD CLASS="quote">pull the ecu fuse for like 10 mins..then put it in and let it idle for like 10 mins and it should fix it...</TD></TR></TABLE>
doing that wont fix ****. it'll jus reset the ecu and soon after the light will come back on. since you jus
resetted the ecu and didnt FIX the problem. if one blink means the o2 sensor check the connections
and the sensor then you go on from there. it'll be either connect the wires or new sensor.
Old 08-17-2003, 05:34 PM
tangb2023
Guest
Posts: n/a
Default Re: help me! (Mr. Choi)
do u have an ek.? check connections. is there an secondary o2 , check that.. mine did that once.. was not the o2 though.. i had a crack in the header causing it to go off. they sell o2 sensor at kreagen for 25..or pep boys.. ask moe
Old 08-17-2003, 11:49 PM
projectEK9's Avatar
Default Re: (JDMB16AEK9)
I bought a bosch one and thats the one I installed. The wire seems a little short so I had to yank on it a little to connect it.
Old 08-17-2003, 11:50 PM
projectEK9's Avatar
Default Re: (projectEK9)
Where is the secondary sensor exactly?
Old 08-17-2003, 11:51 PM
projectEK9's Avatar
Its a d16y7
Old 08-17-2003, 11:59 PM
tangb2023
Guest
Posts: n/a
correct me if i am wrong, but i believe the secondary 02 is screwed into the cat-converter..careful streatching ur wires, just undo the electrical tape then streatch it..
Old 08-18-2003, 03:10 PM
Terry.Ho's Avatar
The secondary is at the rear of the cat. Did you have to splice the wires to connect the new one or did the one you bought have a plug on it? I've tried both on various Civics and the ones that I had to wire always gave me trouble.
Old 08-18-2003, 03:49 PM
all stock's Avatar
try replacing the o2 sensor with your friend's working one. that way you know it works.
John3
11-13-2017 11:43 AM
skaternak
07-10-2008 07:46 PM
boosted111EG
07-05-2007 07:42 PM
EGbeater
12-17-2003 07:02 PM
projectEK9
08-18-2003 09:44 AM
Quick Reply: help me!
