help with ls/vtec
Re: help with ls/vtec
as for the block, you can run any b18 block. u can run p30/pr3 b16 pistons, or ITR or even ctr. depending on what compression you want. as rods and crank. and stock b-series rods will do and crank...
search this...tons of articles on these builds.
i'd say jdm honda p30 pistonsm you'll get a 11.8 - 12.1 compression depening on head gasket thickness(layers), perfect for daily driver ALL MOTOR. a stock ls bore is 81mm and these pistons are also 81mm, on LS rods,and get new bearings if you change pistons, you dont want to blow up a old stock bottom block
hatchdrvr
08-08-2003 04:08 PM
chuckd05
03-26-2003 08:15 AM
